automatic gsr tranny
I bought a jdm b18c automatic motor since usually automatics haven't been abused as much. I also bought a gsr tranny and I'm wondering if it will bolt right up to the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">it should bolt right up, if you have flywheel and clutch and a halfshaft with axles</TD></TR></TABLE>
yes i do. thanks.
yes i do. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">JDM b18c...I have one out of an automatic integra...but i dont think they call them GSR's there...SIR-G I think</TD></TR></TABLE>
yeah something like that. reason why i bought it was because i took the valve cover off and the cams weren't scratched up and the inside was clean. did compression test on a cold motor for some reason all 4 cylinders w/ oil were 300psi i don't know why, but yeah it was a cold engine that hasn't been started up for a month or so i assume the motor is going to have good compression after i start it up.
actual its abnormal...your compression readings cold are almost always lower than when its warmed up...Because of the fact that oil is helping the rings seal when warmed up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">actual its abnormal...your compression readings cold are almost always lower than when its warmed up...Because of the fact that oil is helping the rings seal when warmed up</TD></TR></TABLE>
yeah well I'm sure the motor compression is still good. but you're right about the motor being cold and compression being low.
i need to find- JDM OBD2 GSR AUTO TRANNY
JDM OBD2 GSR AUTO P72 ECU
JDM OBD2 GSR AUTO TCM(transmission control moduel)?
JDM OBD2 GSR AUTO WIRE HARNESS
CAN YUO HELP ME WITH ANY OF THIS?
hatcht9x
11
May 31, 2008 03:37 PM
t-town_ep
Oct 10, 2007 06:49 PM
