Teg hub swap
yes, but they will throw the geometry off, so it won't be aligned right. you reall should get the 90-91 EX front knuckles/hubs/calipers/rotors.
oh wait, do you just want the hub? i don't know about that. they are the same spline pattern as an Si, but i don't know about bearing size...
90-93 teg hubs throw off your camber towards the postive. You can lower the car to correct this.
<--- Who ate a set of tires in no time due to f'd up camber from this conversion.
DB1_559
21
Apr 19, 2008 05:48 PM
91civicDXdude
17
Jun 21, 2003 12:32 PM
customx_
Jan 14, 2002 04:54 AM
