SKUNK manifold
i have a b18c in my 88 hf and now i have a skunk manifold but i don't know if i can get my manifold off because it looks pretty close to the firewall. Will i be able to take my manifold off or do i have to pull the motor?
I am a dumbass for not putting it on before my swap.
you should be able to pull it off on the car......my friend with his b16 could pull his skunk manifold off while its in the car....but the b18c might be a little bigger......the only way to really find out is to try it!!
good luck
good luck
should be no problem if you have the common swap mounts.
it just needs to move like 1/2-1 inch back to take the manifold off.
I remember back in the early days of swapping and no swap mounts were available yet and the rewelded mounts would make the manifolds hit the firewall during shifting.. on those bad swaps.
Wil
Wil
curtissays
Feb 4, 2005 11:43 PM
sloweredcivic
Feb 4, 2005 10:30 PM
