No clutch pressure on pedal, hydrolic
You have to pull it back, no release, it supposedly has a newer M/C. Anything I can check for to determine either the slave cylinder or master sylindeR?
thanks
thanks
Look up under the dash where the clutch rod goes into the end of the clutch master for fluid leaks; next check the slave cylinder on the front of the trans for leaks. Fluid level in the reservoir is worth checking as well.
they all seem fine, dont see any leaks anywhere, whats the clutch damper assembly on the trans?
