6th Gen Electrical Problem
Old Feb 12, 2007 | 05:39 PM
Meighty7's Avatar
Default 6th Gen Electrical Problem
Well we have a sixth gen in the family arsenal and I was driving it back from the food store when I was on a main road giving the car gas and it shutoff completely all the lights came on after about 20 seconds when I pulled into a turn lane. I turned the key back and removed it waited a second started it and the car came on but once again before I could pull out it cut off, the instrument panel went dark once again and all the lights came on. The third attempt made it home with no problems but I was just wondering if anyone had a similar problem and knew the steps to take to fix it.
Old Feb 12, 2007 | 05:42 PM
hondadude's Avatar
Default Re: 6th Gen Electrical Problem (Meighty7)
Well if we knew WHAT YEAR someone could check for ignition switch recall info.
Old Feb 12, 2007 | 06:20 PM
Meighty7's Avatar
Sorry bout that, it's a 1999 LX 4dr 4cyl
Old Feb 12, 2007 | 07:45 PM
YeuEmMaiMai's Avatar
ignition switch recall done? owner link will tell you if it has been performed.
loose ground strap?
Old Feb 13, 2007 | 01:32 PM
Meighty7's Avatar
Checked and made sure the groundstrap was tight when the problem occured before I'll check it agin and see if that recall was taken care of thanx for the help.
Old Feb 13, 2007 | 04:10 PM
JimBlake's Avatar
Default Re: (Meighty7)
My experience with OwnerLink is that site didn't know about the recalls. Call a dealer. Any dealer can look up recall status with your VIN.
Old Feb 13, 2007 | 04:15 PM
Meighty7's Avatar
Okay thanx.
shytdoode
May 7, 2009 01:31 AM
Mike36
Dec 11, 2006 08:03 PM
specie
Nov 25, 2004 02:21 PM
rasta420
Nov 21, 2003 05:56 AM
EJ8 Kenobi
Sep 30, 2003 12:39 PM
