Newb to welding, my first 7018
Old Feb 12, 2007 | 04:40 PM
awdgsx96's Avatar
Default Newb to welding, my first 7018
What's up guys, I'm 16 and this is my first set of welds with 7018 rods in my welding class. Sophomore class, first year of welding. I already padded a 4x6 piece with a 6011 rod, here is my first 7018. I am now working on a better one this is alot tighter which I will also post pics of.
Old Feb 12, 2007 | 05:38 PM
9bells's Avatar
OG Fabricator
Default Re: Newb to welding, my first 7018 (awdgsx96)
This is a good start.
Stick with keeping the welds tight together.
They seem a bit cold. Should be 125 amps for 1/8" at least.
It's great practice to get a feel for the flow, but start doing
fillet welds on top of eachother in the flat/horizontal postion.
The starts are a little wonky. Strike it like a match, don't hit it
like I see so many do.
Make sure to wear a mask/respirator.
Keep on truckin'.
Old Feb 12, 2007 | 07:08 PM
HamiltonRex's Avatar
Default Re: Newb to welding, my first 7018 (9bells)
do lap and t, then multipass T. ( 3 pass)
i did the same thing in highschool, even did some overhead and vertical up/down, its a pain.
Old Feb 13, 2007 | 03:13 AM
TOFU.man's Avatar
Always remember when sticking 1 inch of rod equals 1 inch of weld too. so you should only use about half or a little less of that rod with a 4x6 plate. Stick welds if done correctly can look absolutely beautiful
Old Feb 13, 2007 | 05:30 AM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">This is a good start.
Keep on truckin'. </TD></TR></TABLE>
Yeah, I'm at about 120 amps. I also found out about the match striking method, you will see it on my next padding poject. I'm in my US1 class now, I go to welding for my 6th period, so by the end of this week it will probably be finished. I started on it yesterday, and my first 3 passes are so much tighter and started alot better. I'll be sure to post more and thanks all for the time to post.
vsmhatched
Welding / Fabrication
26
Oct 17, 2006 03:51 PM
Schister66
Sep 14, 2006 08:21 PM
Boosted_K03
Nov 22, 2004 07:41 AM
TriK
23
Feb 13, 2003 04:46 PM
