crazy a/f readings
i was working on my cousin's integra that i just finished boosting and it was running a little rich, it didnt matter too much cuz i had the msd on it so it never fouled the plugs. he kept buggin me to put his fpr on so i did. when i started the car up the baseline pressure was 45psi and the car started to surge a little bit and the gauge was reading all the way in the lean, even when i stepped on the gas. so i put everything back to stock and the gauge is still reading lean. when i open it up its still runs exactly the same. I have no clue if the gauge is right or wrong. can i get some help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">what are you judging these readings from? do you have a wideband installed?</TD></TR></TABLE>
Hopefully it's a wideband, because I could give you better advise without even looking at the car if it's a narrow band.
ummm no its just a regular o2 sensor but it was reading rich this morning and i messed with it and now its reading lean. im not saying its 100% accurate but i know something has changed. I just wanna know what it could possibly be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mightymaxgst »</TD></TR><TR><TD CLASS="quote">ummm no its just a regular o2 sensor but it was reading rich this morning and i messed with it and now its reading lean. im not saying its 100% accurate but i know something has changed. I just wanna know what it could possibly be.</TD></TR></TABLE>
Since it's a regular (narrowband) O2, the gauge is pretty much a useless light show. Your readings are not going to be useful unless you use a wideband O2.
spankey167
13
Oct 13, 2004 10:09 AM
