Anyone have a problem with there GAs tank door>?
Went to the gas station, and the gas tank door wouldnt open
so with no gas and no help i had to pry the door off and the cable broke.
does anyone one know how hard it is to replace the cable?
Does the lever have any tension on it? If not... this could be your problem...
http://www.fueldoorfix.com/
DUde thanks man.... but i honestly I broke the F'n door like a teef at the gas station and the head is broken off the cable inside the where the door is
so im not sure this will work...FACK
Yeah man all you would have had to do is to get some needle nose or slip joint pliers and yank on the cable in the cabin to get it open... But from what you are telling me, you will need to replace the entire release cable.
But good luck to ya either way man.
