Brown milky substance under oil cap
Old Feb 12, 2007 | 09:25 AM
97CWITR's Avatar
Default Brown milky substance under oil cap
Went to top up my oil and found milky light brown coloured stuff under my oil cap.
I'm sure it's a result of my engine overheating a week before.
What does it mean? Coolant in the oil? blown headgasket?
Anything else i should check for?
Thanks
Old Feb 12, 2007 | 09:28 AM
yc_dc4mar's Avatar
Default Re: Brown milky substance under oil cap (96BLkGSR)
yes your are right. blown head gasket. you got coolant in your oil.
you better get that fixed asap
when you replace your head gasket make sure you also replace your thermostat. thats most likely gone too.
and im not sure if theres anything else. if you want, when you pull off your head check it out and make sure its ok. when i over heated my engine, a chuck was missing from one of my valves.
goodluck
Old Feb 12, 2007 | 09:42 AM
nate_2k5's Avatar
Default Re: Brown milky substance under oil cap (yc_dc4mar)
x2 .... or i guess
Old Feb 12, 2007 | 03:02 PM
97CWITR's Avatar
Would i not have the same stuff in my oil pan then?
Talked to a reputable engine builder today he explained that during really cold weather and heat cycles condensation mixes with oil to make that...
anything else i should look for before taking the head off?
Old Feb 12, 2007 | 03:06 PM
nate_2k5's Avatar
you could suck up some coolant and check the color of it
Old Feb 12, 2007 | 03:18 PM
Shank6510's Avatar
Water in the oil possibly... Seriously I asked this exact question to my autos teacher this morning.
Old Feb 12, 2007 | 04:14 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Brown milky substance under oil cap (Shank6510)
Cant you do a leakdown to check for this as well?
99Accord1
Mar 2, 2017 10:15 AM
JdmJah
16
Feb 19, 2013 06:42 PM
Bond
20
Nov 2, 2005 03:12 PM
vtec.dc2
Aug 15, 2003 06:33 PM
G3gsr
May 20, 2003 06:17 PM
