Installing Heim-Type Endlinks
Old Feb 12, 2007 | 07:41 AM
MidwestSiR's Avatar
Default Installing Heim-Type Endlinks
I have Function7 LCA's and I'm installing some Function7 Heim joint endlinks today. I was wondering if i should use spacers (washers) like shown in this pic (from the georgelb write up). Or can I just use the endlink and the supplied nut?
Old Feb 12, 2007 | 07:47 AM
pdiggitydogg's Avatar
I used nylon washers, on the backside, where the link met the lca - significantly reduced knocking w/ my function7 pieces.
(but thats all)
Old Feb 12, 2007 | 07:53 AM
MidwestSiR's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I used nylon washers, on the backside, where the link met the lca - significantly reduced knocking w/ my function7 pieces.
(but thats all)</TD></TR></TABLE>
so basically just to remove and noise that can be caused from the links? I think i'll clear up what i'm asking:
Can the links be crooked..? or should they be straight (vertical) to the swaybar.
Old Feb 12, 2007 | 09:30 AM
dema12co's Avatar
Default Re: (MidwestSiR)
I think he just hadn't tightened his down yet, they should definately be straight.
Old Feb 12, 2007 | 09:42 AM
MidwestSiR's Avatar
Default Re: (dema12co)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dema12co &raquo;</TD></TR><TR><TD CLASS="quote">I think he just hadn't tightened his down yet, they should definately be straight.</TD></TR></TABLE>
i know they're not straight in the picture cause the car was up in the air... i'm asking if it matters if they're at like a 30 degree angle when the car is down due to there not being spacers
Old Feb 12, 2007 | 11:16 AM
blaze the chemi's Avatar
https://honda-tech.com/zerothread/1452650
^^^^^^^ check this How to and see if it helps your situation.
Old Feb 12, 2007 | 11:20 AM
MidwestSiR's Avatar
Default Re: (blaze the chemi)
.... that's where i got pictures for the first post of this thread..
Old Feb 12, 2007 | 11:33 AM
i-VTEC_do_you's Avatar
i would space it out just enough to clear the recesse of the LCA then enough so that it doesn't touch the LCA through the full range of motion of the suspension, then your good.
Old Feb 12, 2007 | 11:34 AM
MidwestSiR's Avatar
Default Re: (i-VTEC_do_you)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_do_you &raquo;</TD></TR><TR><TD CLASS="quote">i would space it out just enough to clear the recesse of the LCA then enough so that it doesn't touch the LCA through the full range of motion of the suspension, then your good.</TD></TR></TABLE>
thank you
Old Feb 12, 2007 | 11:37 AM
no prob!
mugenpovver
Feb 16, 2008 02:50 PM
.water
Welding / Fabrication
24
Nov 8, 2005 08:50 PM
shocker
Oct 5, 2005 10:34 PM
chrish
May 15, 2004 09:48 PM
SRSNOS
Oct 9, 2003 04:16 PM
