JDM CRX EF7 and EF8
Old Feb 12, 2007 | 07:33 AM
harmonator84's Avatar
Default JDM CRX EF7 and EF8
I am getting ready to order a front end conversion for my crx. Is there a difference between a jdm ef7 and a ef8 front end? Could I order some ef7 parts and some ef8 parts and they all work fine together?
Heres a pick since I know that pics bring people!
Old Feb 12, 2007 | 07:36 AM
crxxxrc's Avatar
Default Re: JDM CRX EF7 and EF8 (harmonator84)
what year is your crx?
Old Feb 12, 2007 | 07:39 AM
Default Re: JDM CRX EF7 and EF8 (crxxxrc)
90
Old Feb 12, 2007 | 07:46 AM
EFOSV.'s Avatar
yes theyre different , no they wont work fine together ....
Old Feb 12, 2007 | 08:03 AM
Default Re: JDM CRX EF7 and EF8 (EFOSV.)
so what is the difference between ef7 and ef8.
I need to know because I am getting ready to order some parts.
Old Feb 12, 2007 | 08:08 AM
Boosted Chemist's Avatar
ef7 88-89 uses a bump style hood that works on usdm fronts. Also they have plastic head lights that work too.
ef8 ef7 90-91 all crx made for jdm markets had the "sir" front end, this includes 1.5x, ef7,ef8 ect. This you need the bumper, headlgihts and hood to make it owrk on your crx
Old Feb 12, 2007 | 08:12 AM
Default Re: JDM CRX EF7 and EF8 (Boosted Chemist)
after doing some research I think I see now..
So the ef7 just has the hump and the hood. Thats the only difference between ef7 and a ed right?
Old Feb 12, 2007 | 08:18 AM
EFOSV.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">So the ef7 just has the hump and the hood. Thats the only difference between ef7 and a ed right?</TD></TR></TABLE>
plastic one bulb headlights , corners lights , bumper i guess is different too and fenders with sidemarkers .....
Old Feb 12, 2007 | 08:31 AM
8889 zc
90-91 zc
Old Feb 12, 2007 | 09:26 AM
I cannot tell a difference between 90-91 zc and the ef8?
Old Feb 12, 2007 | 09:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">I cannot tell a difference between 90-91 zc and the ef8?</TD></TR></TABLE>
Cause all crx came with the sir front in 90-91, ef8,ef7, you name it.
Old Feb 12, 2007 | 09:52 AM
so the only difference in a ef7 and a ef8 front end is the 88-89 model ef7's. A 90-91 ef7 and ef8s front ends are the same?
Old Feb 12, 2007 | 09:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">so the only difference in a ef7 and a ef8 front end is the 88-89 model ef7's. A 90-91 ef7 and ef8s front ends are the same?</TD></TR></TABLE>
yes minus the t bar, the radiator support, the zc, si, 1.5x all have a simialar chassis to the usdm crx. The ef8 nose is about 1" longer then the other chassis. That is why you have to modify your t bar (usdm) to work on this front end. The ef7 and 1.5x both came with larger tbars that accomadate the "sir" front on a usdm car perfectly.
Old Feb 12, 2007 | 09:59 AM
so what your saying is that if i get a 90-91 ef7 front end I will not need the tbar?
Old Feb 12, 2007 | 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">so what your saying is that if i get a 90-91 ef7 front end I will not need the tbar?</TD></TR></TABLE>
No, all the 90-91 front end parts are the same. Just the ef7 tbar will allow you to bolt it up, no shimming like the usdm or ef8 tbar on a usdm chassis. Its just a bonus, no big deal, i wouldnt go pay more than 40 for it, some peole want 150, where 2 bucks worth of washers can make your usdm work fine.
Old Feb 12, 2007 | 10:04 AM
great because the company I am ordering it from doesnt know if they have a tbar. I will just use my stock one and some washers and line it up myself. Thanks.
B16CRXVTEC
Nov 8, 2009 08:33 AM
Eg6hybrid92
Mar 2, 2006 03:52 PM
EFing_bmxED
13
Nov 5, 2005 04:51 AM
Mr_Si-R
Sep 28, 2005 12:58 PM
CRX_fiend
17
Nov 24, 2004 06:59 PM
