Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 Civic shift lock engaged... rear brake lights not working
Old Feb 12, 2007 | 06:03 AM
bellyboy's Avatar
Default 04 Civic shift lock engaged... rear brake lights not working
Hey
Seems we have to insert our key into the shift lock hole to disengage the shifter. Research we have done tells us the shifter is locked because there is something wrong and should be coded to determine whats up. Our brake lights are not working (none of them). I have a gut feeling it is the brake light switch.
Any thoughts on how to determine what it might be, tricks on ruling different items out?
Thanks
Brian
Old Feb 12, 2007 | 07:49 AM
Jon Vito's Avatar
you popped a fuse man. the same thing has happened to me. check the fuse box in the engine bay. i cant remember what fuse it is, buts its a 15. ill look later and get back to you
Old Feb 14, 2007 | 06:39 PM
bellyboy's Avatar
Default Re: 04 Civic shift lock engaged... rear brake lights not working (bellyboy)
thanks
it was the brake light switch, right at the brake pedal. it cost 9 bucks.
it also does something for the cruise.
so if you brake lights dont work and you cant get your stick out of park it is very good chance you need a brake light switch
Old Feb 17, 2007 | 11:14 PM
Jon Vito's Avatar
mine was just a blown fuse
oohtruck
Sep 17, 2012 08:46 AM
Type-Spaz
Oct 2, 2011 04:44 PM
ATLHONDA
Mar 22, 2010 04:34 AM
Chee_dog
29
Aug 15, 2009 03:17 PM
menappi
May 7, 2004 01:23 AM
