EK honda access window visors install. help?
searched, found two but the pictures are outdated and probably deleted by now since theyre old posts. anyone out there willing to make a new write up with pictures for visual learners like myself? thanks in advance! my visors look sad in the back seat due to my lack of knowledge on installing them correctly.
I have the pictures from one of the installs. I will send them you you guys, just shoot me a pm with an email.
It is easy as pie! The hardest part for me was putting the plugs through the visor to the bracket.
Other than that it was simple!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichatch2k »</TD></TR><TR><TD CLASS="quote">I have the pictures from one of the installs. I will send them you you guys, just shoot me a pm with an email.
Other than that it was simple!</TD></TR></TABLE>
PMed you
PMed you
I did these recently and am going to have to do them again soon. Will try doing a write up.
You gotta start by removing the seal around the window. Once you do that you will notice some premade holes. Each little clip you recieved will have to go screwed in there. Its like 4 on each side. Wow this is very hard to explain. We'll see if i can help
Step 1
Remove both seals from the door.
Step 2
Find the 2 holes at the beginning and the end of the frame.
Step 3
Screw in 2 brackets on each side. Note: only use the brackets with the premade threads to screw into and it has the oval opening where the visors will attach.
Step 4
Now mock up the visors and place the clips where they should fit on the track.
Step 5
The washers are used to fit behind the brackets that are oval. 4 total. They are the ones from step 2.
Step 6
Place all the female rivet things first, then the male rivets.
Sorry this wasn’t a complete step by step but it can be figured out.
We be glad to answer any questions.
Step 2
Step 3
Step 4
Step 5
Step 6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hasback* »</TD></TR><TR><TD CLASS="quote">
give me 20 bucks n ill do that **** in less then 10 minutes.
thats what i thought too! took my *** like an hour trying to get the rubber seal in right, and after that i was still getting air noise while driving! so i sold the car(not really tho).
</TD></TR></TABLE>thats what i thought too! took my *** like an hour trying to get the rubber seal in right, and after that i was still getting air noise while driving! so i sold the car(not really tho).
jime64871
78
Jan 4, 2020 08:25 PM
kaluwa3
37
Oct 30, 2016 12:09 PM
ejONE.mike
May 26, 2006 02:27 PM
OneSickJDMBB6
Jan 30, 2006 04:56 PM
