Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tires for track suggestions?
Old Feb 11, 2007 | 11:37 PM
Soku1kcivic's Avatar
Default tires for track suggestions?
Hi all, I am looking to buy some tires for hpde or track events i been to about 6 hpde events with cheapy tires. I am thinking about spending around 60-80 dollars on each tire. The car is an eg hatch with stock suspension and stock b16a motor. The rim is bbs 14x6 wheel. These tires will never see street (only track). I would like to know what size tire and specs rating like hr or z etc to get thanks?
Old Feb 11, 2007 | 11:41 PM
osprey's Avatar
Default Re: tires for track suggestions? (Soku1kcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soku1kcivic &raquo;</TD></TR><TR><TD CLASS="quote"> These tires will never see street (only track). I would like to know what size tire and specs rating thanks?</TD></TR></TABLE>
what is your driving style and how much seat time have you had?
I ask because I would not reccomend a race compound to anyone if they are still learning the basics. Or still mastering it.
the new azenis have an acceptable heat range for HPDE and still have that squeal if youre doing something wrong. the Hankook equivalent is also a good choice.
but if you are good enough I'd say the toyo RA1s would be a good choice entry level R-Compound
Old Feb 11, 2007 | 11:49 PM
Default Re: tires for track suggestions? (tehBenz0r)
I would say about total 4hrs of seat time iam still a beginner i just want to get something a little better than the 30-40 dollars per tire that i had. Just wanted to know what brand, tire series, and rating to get this time (for sure not R ratings)
Old Feb 11, 2007 | 11:52 PM
osprey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soku1kcivic &raquo;</TD></TR><TR><TD CLASS="quote">I would say about total 4hrs of seat time iam still a beginner i just want to get something a little better than the 30-40 dollars per tire that i had. Just wanted to know what brand, tire series, and rating to get this time (for sure not R ratings)</TD></TR></TABLE>
oh in that case, the hankook ventus might be of interest. I think they are cheaper than the azenis but supposedly are comparable in performance.
A 195/50/14 might work for you. Im not sure, the smallest wheel I used for HPDE was 15x7 and my tire was a 205/50/15.
Old Feb 12, 2007 | 08:24 AM
nsxtasy's Avatar
H-T Order of Merit
Easy choice! Falken Azenis RT-615, 195/60-14, $61/tire at Vulcan. End of discussion.
Old Mar 1, 2007 | 09:23 AM
1_slow_crx's Avatar
Default Re: tires for track suggestions? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Easy choice! Falken Azenis RT-615, 195/60-14, $61/tire at Vulcan. End of discussion.
i was wondering how everyone has been breaking in their azenis ?
Old Mar 1, 2007 | 10:00 AM
mos's Avatar
mos
Default Re: tires for track suggestions? (1_slow_crx)
By driving to the track? I had just as much fun with azenises on 14x5 stockers as I do with them on 15's now.
Old Mar 1, 2007 | 10:06 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote"> End of discussion. </TD></TR></TABLE>
not so fast
I have brand new a set of 195/60-14 Azenis 215s sitting in my garage. I'll let them go for $180 for the set for 4 (thats $45 ea!). They've never been mounted.
I'm Located in South OC
Steve
Old Mar 1, 2007 | 10:24 AM
6spdKEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">
They take about 50-100 of normal driving to rub off the mold residue.
Old Mar 1, 2007 | 11:13 AM
pos_cd5's Avatar
Default Re: tires for track suggestions? (6spdKEG)
dont brand new performance tires need to be heat cycled to perform to their max potential? for those whodont pay the extra cost to get them heat cycled, whats your method?
Old Mar 1, 2007 | 11:24 AM
Johnny Mac's Avatar
Default Re: tires for track suggestions? (pos_cd5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 &raquo;</TD></TR><TR><TD CLASS="quote">dont brand new performance tires need to be heat cycled to perform to their max potential? for those whodont pay the extra cost to get them heat cycled, whats your method?</TD></TR></TABLE>
To break-in and heat cycle the tire, drive approximately 100 miles of normal driving. The continual flexing of the carcass and rubber compound generates the heat, which completes the heat cycling process. Also, put about 30 psi cold air pressure in these tires for normal driving.
Old Mar 1, 2007 | 11:43 AM
.RJ's Avatar
.RJ
Default Re: tires for track suggestions? (Johnny Mac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Mac &raquo;</TD></TR><TR><TD CLASS="quote">put about 30 psi cold air pressure in these</TD></TR></TABLE>
Where do I find cold air?
Old Mar 1, 2007 | 11:46 AM
nonsense's Avatar
Default Re: tires for track suggestions? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Where do I find cold air?</TD></TR></TABLE>
it shouldn't be hard to source in VA
Old Mar 1, 2007 | 12:57 PM
Johnny Mac's Avatar
Okay, let me re-phrase my suggestion about tire pressures since RJ brought up a good point.
Put 30 psi of air at any temperature of the source, or make sure that there is 30 psi in the tires before the car has been driven or at least a couple of hours after it has last been driven. Now, if the car is being driven on Venus or close to the Sun, disregard this advice.
Old Mar 1, 2007 | 02:28 PM
Lo-Buck EF's Avatar
oh boy...
Old Mar 2, 2007 | 08:04 AM
mos's Avatar
mos
Default Re: tires for track suggestions? (blackdc5)
30 is about right for those tires. Even on Venus. Dibs on nonsense's tires.
Conan the Destroyer
12
May 5, 2009 12:53 PM
Godspeed07
16
Mar 9, 2008 06:57 PM
ExplicitSpeed360
Nov 1, 2005 11:28 AM
hYbRid_Eg6
Jun 14, 2005 09:01 PM
TaboR
Nov 24, 2001 07:17 PM
