Water cooled torch ??s
IS it possible to replace the power cable part of a water cooled torch?
I have an older unknown brand torch that came w/ my uber tig from 1963 and it gets toasty warm when welding even with moderate amps and water. I'm starting to think the cable is corroded or shot. Or am I wrong and toasty warm cables normal?
Check to see if your pump is working. If the cable was shot that would most likely mean it had a hole. If that was the case, you would be squirting water out of that hole. Sounds to me as if your pump isn't working or you are out of water (if not a direct hook up)
Yes you can replace the power cable/hose assembly on most troches. If your torch is that old then it would be in your best interest to change it out for a new one. You can buy a new 25' hw20 torch assembly all new from indiana oxygen supply for $128 and free shipping the power cable is going to cost you the bulk of that especially if you go to your local welding supply. HW20 torch is a great size for all around work. Very small head with a 250 amp rating and you can also get a 320 amp rated torch but they are significantly more $ I have 2 of each. They only thing you may need is the power block which adapts the torch to the water and also the power lug if yours is different.
B18PoweredCivic
Jul 25, 2003 01:37 PM
