F/S: B18B/LS Head, Garrett/Autometer Gauges, Misc D/B Series Stuff
JDM LS/CRV P75-2 head - Head stamp says it's a 96. Came off a JDM B20B with ~30k miles on it. Good condition, what you see is what you get. Make an offer
Garrett Mechanical Boost Gauge - Reads vacuum and up to 30psi boost. Nice Garrett logo and bright illumination. Used for about a week - essentially new. Comes with all included hardware and wires intact in original box. $40 picked up/$45 shipped.
Powerflow Stainless Muffler - Brand new 6"x16" round muffler. Straight through stainless design with 2.5" inlet/outlet. $30 picked up/$40 shipped.
OEM Rear LCA's - fit 96-00 Civics, make an offer
OEM springs - fit 92-00 Civics and 94-up Integras, make an offer
OEM Civic shifter arm - make an offer
D Series SRR Flywheel - Lightweight SRR chromoly flywheel for D series engines. Bought and never used because my clutch didn't fit on it. I believe it uses the smaller diameter D series clutch. Comes with new pilot bearing. Make an offer.
D16Y8 starter motor - off a 97 EX MT, $50
D16Y8 Shift Linkage - comes with poly ES bushings, $30
D16Y8 oil pump - ~1000 miles on it, $30
D16Y8 internals - complete internals from my 97 shortblock, #3 piston has cracked ringlands, make me an offer
D16Y8 backup light switch - $10
D16Y8 crank pulleys - 2 available, make an offer
D16Y8/B18B engine mounts - D16Y8 AC mount, front tranny mount, upper tranny mount(on chassis), rear chassis mount, rear tranny bracket; LS front torque mounts(on chassis); make an offer an any or all
98 LS power steering pump, pulley, belt(not pictured because I have several belts lying around and I don't know which one it is), bracket - 60k miles, make an offer
98 LS clutch disc, pressure plate - Very low miles, a lot of meat left, make an offer
98 LS flywheel - good condition, make an offer
98 LS fuel pump - 60k miles, make an offer
98 LS intake manifold bracket - make an offer
________________
Buyers pay shipping costs on all items, unless otherwise noted.
I prefer not to ship the heavier/bulkier items for obvious reasons.
All parts listed are from a 97 Civic EX or 98 Integra LS, unless otherwise noted.
I'm in San Jose, Cali.
Modified by inspyral at 4:58 PM 7/27/2007
________________
How much for the 98 LS clutch disc and pressure plate. Do you know if the clutch disc and pressure plate will fit a b16? Also the rear chassis mount. PM me a good price shipped to 79605. Thanks.
Modified by 91_Civic_Hatch at 7:25 PM 4/9/2007
Is this the bracket that comes on a b16a 1st gen? If you want, you can take more pics and send them to my email. my email address is dinbrin@yahoo.com Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_Civic_Hatch »</TD></TR><TR><TD CLASS="quote">Is this the bracket that comes on a b16a 1st gen? If you want, you can take more pics and send them to my email. my email address is dinbrin@yahoo.com Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">
None of the mounts are first gen B16A mounts.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">
'm interested in the flywheel, but can you post some pictures with a tape measure laid across the clutch mating surface to see if the diameter is 212mm (approx. 8.35in) or 200mm (approx. 7.87in)?
also could i get a quote on shipping to Cincinnati, OH 45245? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon »</TD></TR><TR><TD CLASS="quote">'m interested in the flywheel, but can you post some pictures with a tape measure laid across the clutch mating surface to see if the diameter is 212mm (approx. 8.35in) or 200mm (approx. 7.87in)?
Here you go.
These show the overall diameter:
This shows the diameter from edge to edge of the friction surface:
This shows the diameter of the pressure plate bolt holes:
Shipping is about $20
Here you go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">I see only red "x"</TD></TR></TABLE>
Image server is probably down, check back later.
inspyral
Oct 1, 2007 11:20 AM
inspyral
Oct 1, 2007 11:19 AM
inspyral
Northern California (Sales)
12
Aug 14, 2007 07:05 PM
inspyral
Aug 14, 2007 07:04 PM
