help wire an h23 into accord
Old Feb 11, 2007 | 08:00 PM
cbh23's Avatar
Default help wire an h23 into accord
ok i have a 1993 accord with a busted up wire harness i have checked all junkyards i can find i have searched ebay and all over the net and still cant find the harness for it i dont have the secondaries on my engine so i dont know how to wire the regular accord wire harness into the h23 i have heard u can wire in the iab into the ecu and i could use the regular accord harness that way but i dont know what the iab is or how to wire it in?!? any help would be highly appreciated
Old Feb 12, 2007 | 04:50 AM
Speedra500's Avatar
Default Re: help wire an h23 into accord (cbh23)
the IABs are the secondary butterflies in your intake manifold, the vacuum manifold/solenoid that controls them in mounted on the bottom of the intake manifold. Your harness does not have wires for them so you'll have to run you're own either to the ECU or you could probably put pins in your factory harness for a cleaner look
Old Feb 12, 2007 | 05:01 AM
flavah0wnz's Avatar
Default Re: help wire an h23 into accord (Speedra500)
i have an h23 harness if u want it
Old Feb 12, 2007 | 10:38 AM
cbh23's Avatar
Default Re: help wire an h23 into accord (flavah0wnz)
SWEET exactly what i need how much u want for it i need the whole thing under the dash and all???
cbh23
Feb 12, 2007 05:52 PM
accuder
Feb 11, 2007 07:08 PM
accuder
Feb 11, 2007 05:24 PM
