Venom intake manifold - Fuel Rail mounting ??
Old May 19, 2002 | 01:01 PM
zilverz's Avatar
Default Venom intake manifold - Fuel Rail mounting ??
http://www.venom-performance.com/NF/...fold-_Blue.gif
umm from the looks of this manifold .. it had grooves that look like they would hold the fuel rail on ... but i dont see any studs ? soooo does that mean this intake manifold will only securely hold down a Venom fuel rail and not say... an AEM ? cause i dont see studs for the nutzzz,.. or am i just blind ? (:
Old May 19, 2002 | 01:24 PM
zilverz's Avatar
Default Re: Venom intake manifold - Fuel Rail mounting ?? (zilverz)
Ok i think i might have answered my own question .... do you see what looks like threaded holes ? i think so ... so i would just have to come up with 3 studs then the rail should mount fine .... . anyone have this venom intake manifold and can eliminate my guesswork here ? (:
Old May 19, 2002 | 01:27 PM
Integra_Boi's Avatar
New User
just installed my skunk2.. here are some tips so u dont have to go thru all the trouble i had to go thru...
1. check all ur injectors for O ring tears.
2. Dont drop the O ring that goes onto the manifold for the injectors
3. dont drop the TINY o ring between the fuel pressure regulator and fuel rail
4. replace the intake manifold gasket
5. replace the throttle gasket..
some of this seems like u cna reuse... but my 96 had to replace basicaly everything..
Old May 19, 2002 | 01:34 PM
zilverz's Avatar
Default Re: Venom intake manifold - Fuel Rail mounting ?? (Integra_Boi)
Yea i know exactly what you mean about the tiny orings hehe .. i already did my whole fuel system ...... but gonna have to tear it back down gettin the stock manifold off for the upgrade. |; but i think im going to change out the injectors and throttle body while i have it all broken down
Old May 19, 2002 | 09:50 PM
New User
good luck
LS1Bait
Jan 15, 2009 07:04 AM
central_driver
Aug 28, 2007 12:43 AM
euclid
Jul 20, 2003 10:39 AM
