rewired o2 sensor dont work
Old Feb 11, 2007 | 05:33 PM
novtecnoboost's Avatar
Default rewired o2 sensor dont work
ok so i tried to rewire my o2 sensor because i had just recently got a gsr and the guy who did the swap used my old engine harness from the y7.
so the o2 plug didnt reach to the sensor.
i then extended the wires fromt the o2 sensor to reach the plug but now it is still throwing the same code so any help will help.
maybe i need a new o2 sensor?
Old Feb 11, 2007 | 05:35 PM
Default Re: rewired o2 sensor dont work (theb18c1)
heres the codes i am throwing
p1337
p0135
p1381
Old Feb 11, 2007 | 05:36 PM
pdiggitydogg's Avatar
maybe you just mixed the 2 black wires up
P1381 Cylinder Position (CYP) Sensor Intermittent Interruption
P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
you have more than an o2 issue...
Old Feb 11, 2007 | 05:37 PM
Default Re: (pdiggitydogg)
no cause i rewired those wires twice both ways
Old Feb 11, 2007 | 05:41 PM
i dont know...try a different sensor then
i hope you were smart and didnt extend the car's harness, but did the sensor's wiring instead
Old Feb 11, 2007 | 05:54 PM
thats exactl what i did so i need to buy a diffrent sensor
i was wondering i seen on kragen sensors for like 120 dollers then i seen one for 45 bucks should i pick that one up?
Old Feb 11, 2007 | 06:43 PM
Default Re: (theb18c1)
bump
Old Feb 11, 2007 | 06:56 PM
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">i dont know...try a different sensor then
i hope you were smart and didnt extend the car's harness, but did the sensor's wiring instead</TD></TR></TABLE>
Yeah the car's harness would've been a pain b/c the sensor wire is a double layer wire to get rid of any noise. Unfortunately my harness pigtail for the o2 sensor was ripped apart when my extend o2 wire got tangled in the axle!
Markadler47@gma
Mar 22, 2019 02:36 PM
vtec2nv
Apr 12, 2013 04:52 AM
vrotsos991
Honda Civic (2001 - 2005)
13
Nov 14, 2011 06:31 AM
kelviiv
Jul 9, 2008 10:53 PM
h22dxhatch
Jul 28, 2007 01:03 PM
