got prblem on cd6 97 accord dx
well i love tune accords mine is unmodified i don't even have a intake any way i rplaced water pump,pcv valve sparkplugs head gasket, timing belts distrib cap but this car sakes when i go to like a stop sign like the interior but a little like a moderate shake i figure replace the alternator belt what the fuc is it help please to the accrod gods man
ok I THINK what you are saying is that the car vibrates a little when it comes to a stop?
have you looked at motor mounts? how's the idle speed, etc (also it'd be a cd5 or cd7, cd6 is JDM) mine vibrates a little but nothing too horrible to complain about
what's your idle speed? and are any motor mounts busted up?
rotor warpage, uneven tire pressure/wear, alignment, motor mounts, idle speed, bunch of crap could be the reason
Under braking I believe the most common is rotor warpage and alignment
Idling most likely motor mounts
accelerating most likely tires / alignment / mounts
Someone correct me if I'm wrong
rear motor mount is vacum controlled. Make sure that the line is hooked up and that it is working properly before you replace it.
does the car shake when coming to a stop or is it shaking when you are at a complete stop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">rear motor mount is vacum controlled.</TD></TR></TABLE>
yep, but only on the automatic transmission Accord's.
I don't think he said what tranny he has.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">does the car shake when coming to a stop or is it shaking when you are at a complete stop?</TD></TR></TABLE>
x2
x2
