Honda Chopper
Old Feb 11, 2007 | 04:38 PM
dmotoguy's Avatar
Default Honda Chopper
Here is a hondaka frame with a honda 125 four stroke motor that i'm making into a little chopper.. I've put two or three weekends into it so far.. cutting, bending, welding, grinding.. over and over
my welds aren't the best.. but they'll do.. im having issues with the old tubing having rust on the inside contaminating the welds..
Old Feb 11, 2007 | 04:57 PM
TurboHondaGuy's Avatar
Default Re: Honda Chopper (dmotoguy)
its a chonda...honda chopper, i was gunna build my own bike outta a Suzuki GS550 but im just buying a harley instead, the down fall of what you did tho is your frame is all outta whack now becuz you dont have a frame jig to hold everything straight when you cut it, everything might be off/not straight now but either way you go good luck with the chonda man
Old Feb 11, 2007 | 05:17 PM
DaveF's Avatar
Default Re: Honda Chopper (TurboHondaGuy)
i see the torch out, did you try the sand bending technique?
Old Feb 11, 2007 | 05:46 PM
dmotoguy's Avatar
Default Re: Honda Chopper (dturbocivic)
haha.. i probably will when i make the exhaust for it
Old Feb 12, 2007 | 10:31 AM
HiProfile's Avatar
Darn, I was hoping to see a turbocharged h22 in there j/k
Looks like an interesting project
Old Feb 12, 2007 | 02:04 PM
arc_55's Avatar
It looks to me as that frame might fatigue quite easily, but none the less a very interesting project. I would brace that frame up to be safe.
Old Feb 12, 2007 | 03:09 PM
dmotoguy's Avatar
Default Re: (arc_55)
yea, im still not done with the frame, i had to cut a brace off the top because it hit the top of the motor, so i going to put that back in at a slightly different angle. The next part will be making the rear part of the frame since it will be a hardtail.
hoverover
Apr 16, 2019 02:29 PM
dubzxallxstar
Northern California (Sales)
May 4, 2010 01:18 PM
doublethink
Classic Hondas
36
Aug 24, 2007 04:57 PM
david_mj
Honda Motorcycles
Mar 9, 2006 10:10 AM
MadeInKorea23
Honda Motorcycles
26
Jan 8, 2005 02:14 AM
