shaving b18a valve cover gone awry...
Old Feb 10, 2007 | 09:47 PM
aaronhume's Avatar
Default shaving b18a valve cover gone awry...
well I feel like a total noob now... so I started grinding away my lettering and about halfway down the words to the level of the cover, I started making a hole. basically I'll most likely buy a new valve cover, but is there a good way to finish shaving the lettering? or repair the hole? thanks in advance for input!
Old Feb 10, 2007 | 09:49 PM
DC4KiD's Avatar
Spot/Tack weld it. Then grind it back down.
Old Feb 10, 2007 | 09:51 PM
Orangecivic251's Avatar
Default Re: shaving b18a valve cover gone awry... (aaronhume)
fixing the hole is one things why you did it with the cover still on the car is another that little hole can do some damage if that debris fell through
Old Feb 10, 2007 | 09:56 PM
ATS*Mark's Avatar
OG triple OG
Default Re: shaving b18a valve cover gone awry... (HondaEMS.com)
well if you grided through chances are there are shavings sitting in your head right now . you should feel like a noob
pull that thing off and do it
Old Feb 10, 2007 | 10:26 PM
NFM_Dm's Avatar
did you even use sand paper or did you use like a grinding wheel?
Old Feb 10, 2007 | 10:27 PM
E46Kid's Avatar
Default Re: shaving b18a valve cover gone awry... (ATS*Mark)
Damn talk about knowing how to grind...
Id junk that damn valve cover but if you want to save some money diy fix that **** with some welds
Old Feb 10, 2007 | 10:40 PM
aaronhume's Avatar
Default Re: shaving b18a valve cover gone awry... (Em1Kid)
well I will be changing the head soon anyway, and am now looking for a b20 or 94+ ls valve cover....
I still haven't seen anything about actually shaving that lettering properly yet.
Old Feb 10, 2007 | 10:52 PM
Desired_Speeds's Avatar
isnt a valve cover 2 layers of metal anyways so you only grounded through the top. So theres just shavings in the space between the two layers
Old Feb 10, 2007 | 11:24 PM
Default Re: (Desired_Speeds)
hmm i don't know about that i know that it woulnd't have fallen directly on the cam as in vtec motors has that splash guard thing up there but non the less wouldn't do it to mine
Old Feb 11, 2007 | 01:38 AM
Danger's Avatar
Default Re: (HondaEMS.com)
wow
Old Feb 11, 2007 | 02:02 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Danger)
I sanded down my b18c VC with 60 grit sandpaper, a sanding block, and elbow grease. No holes, no problems
Old Feb 11, 2007 | 02:11 AM
Fook_me_honda's Avatar
Default Re: (SlammedDC2)
we used jb welb on a old beater of mine that had a crack. worked like a charm, cheap easy fix, but not the best cosmetically.
Old Feb 11, 2007 | 02:45 AM
ErMaK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronhume &raquo;</TD></TR><TR><TD CLASS="quote">well I will be changing the head soon anyway, and am now looking for a b20 or 94+ ls valve cover....
I still haven't seen anything about actually shaving that lettering properly yet.</TD></TR></TABLE>
Do B20 Valve Covers fit B18As?
Old Feb 11, 2007 | 10:55 AM
Danger's Avatar
Default Re: shaving b18a valve cover gone awry... (ErMaK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ErMaK &raquo;</TD></TR><TR><TD CLASS="quote">
Do B20 Valve Covers fit B18As?</TD></TR></TABLE>
same head , jus have to plug the hole towards the top of the valvecover .
Old Feb 11, 2007 | 11:10 AM
EJgsr's Avatar
Default Re: shaving b18a valve cover gone awry... (Danger)
just get a new one.
i just gave away like 4 of them.
Old Feb 11, 2007 | 10:24 PM
aaronhume's Avatar
Default Re: shaving b18a valve cover gone awry... (EJgsr)
got one on ebay $10 shipped heh... I'll still shave everything down once I have a good cover on the engine... and just mess around with the other one and see how I can make it look regardless of holes
GrnZ
Apr 10, 2008 11:52 AM
AccordSleeperZzZ
Feb 24, 2008 08:37 PM
Sound Streamin'
Nov 4, 2004 07:14 PM
Utilitarian
Aug 21, 2004 07:03 PM
Edwin
Jul 24, 2002 12:15 PM
