manual tensioner question
im in the process of doing the manual style conversion to my h22a. my question is, is it ok to run without the balance shaft belt? i know alot people take them off, so i dont see why it wouldnt be alright. im just looking for a definitive answer and any adverse affects. thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si »</TD></TR><TR><TD CLASS="quote">im in the process of doing the manual style conversion to my h22a. my question is, is it ok to run without the balance shaft belt? i know alot people take them off, so i dont see why it wouldnt be alright. im just looking for a definitive answer and any adverse affects. thanks!</TD></TR></TABLE>
I dont feel that its nessasary to remove the balance belt, however ppl will remove them for extra oil psi and less rotating mass, is said to help acceleration. they make a eliminator kit, i dont know where but search for it and your find it.
20 lbs less if you do a complete removal of shafts in ****.
its also said that w/ it removed you will get more vibration
im aware of the exess vibration. im just curious to the fact, will that vibration do any internal FUBARing to my motor after the manual tensioner swap?
In what i read it said no, the vibration would not cause any internal damage. they said above 6k is when the vibration would kick in.
In my opnion, the vibration would cause longevity issues. but i dont know.
fiebru1119
Mar 10, 2007 11:57 AM
JDM-accord_94
Nov 15, 2005 07:51 PM
