quick question about b16 swap
i have a 89 hatch si and i was told that i can use 94+ integra axles because its an si year and i dont have to remove the hub
but i was planning to upgrade to DA front conversion brakes, would i still be able to use
the 94+ integra axles or do i have to use 90-93 axles
Now this doesn't directly answer your question, but it's a side note when it comes to axle / hub combinations.
1988 - 91 Std / HF = Small Diameter Hubs
1988 - 00 Civics = 32mm Hub
1990 - 01 USDM Integra = 32mm Hub
JDM Type-R Integra = 36mm Hub
There, now if you ever wonder what axle will bolt to what hub....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker »</TD></TR><TR><TD CLASS="quote">you use the axle that matches the halfshaft ,what halfshaft do you have?</TD></TR></TABLE>
94+ halfshaft and axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 »</TD></TR><TR><TD CLASS="quote">id go with 90-91 integra axels and half shaft, the 94 and up are a little longer</TD></TR></TABLE>
from 88-01 all b-series axles are the same on the passenger side..only difference is hydro to cable axle seals and if they come with the abs ring or not...
for the driverside you always match the axle with the halfshaft,,he says he has a 94 teg halfshaft so that's the axle he needs...
so answer the 2nd question yes those axles will fit into the da integra hubs,go by what dr.latino posted
