Coolant smell in heat with recirc off
Old Feb 10, 2007 | 07:40 PM
ham's Avatar
ham
Default Coolant smell in heat with recirc off
I have a 96 HX and I can smell coolant with the heat on and the recirc button off. When recirc is on, I don't smell anything. I've never had to add coolant and I don't smell or see any leaks or burning outside the car or under the hood.
Is there anything else I can check?
Old Feb 10, 2007 | 07:46 PM
Teknoshaman's Avatar
* B A N N E D *
Default Re: Coolant smell in heat with recirc off (ham)
It only takes a little coolant leaked out to make that smell. your heater core or the hoses might have leaked a little.
Old Feb 10, 2007 | 07:47 PM
ham's Avatar
ham
Default Re: Coolant smell in heat with recirc off (Teknoshaman)
but the smell instantly goes away when i switch the blower to recirculation. i was thinking if it was the heater core, it would stink all the time.
Old Feb 11, 2007 | 12:46 PM
ham's Avatar
ham
bump
Old Feb 12, 2007 | 06:08 PM
ham's Avatar
ham
im thinking maybe theres a tiny leak somewhere and its burning on the exhaust or something and i smell it going into my outside vents.
Old Feb 12, 2007 | 06:26 PM
I'm Trying's Avatar
did you check for coolant leaks?? get your coolant system pressure tested.
Old Feb 12, 2007 | 06:56 PM
Jonknee's Avatar
Default Re: Coolant smell in heat with recirc off (I'm Trying)
dude i had the same problem and it turnd out to be the damn thing where the bleeding screw is , ( where the large radiator hose goes to in the top) and it was leaking onto the header drop by drop. Look around man, good luck
Old Feb 12, 2007 | 06:58 PM
Turbo_y8's Avatar
Default Re: Coolant smell in heat with recirc off (Jonknee)
is you passenger side floor board wet?
Old Feb 12, 2007 | 07:03 PM
Jonknee's Avatar
Default Re: Coolant smell in heat with recirc off (Turbo_y8)
i doubt his passenger footboard is wet, wouldnt that mean it would smell anytime the heater motor is on, his only smells when it takes in outside air ( or i think he said).
Old Feb 12, 2007 | 07:08 PM
Turbo_y8's Avatar
yea, im just saying it to eliminate a possible problem. and its easy. put your hand down there. done.
Old Feb 13, 2007 | 02:33 AM
ham's Avatar
ham
i checked it out for like an hour... i cant find a leak anywhere. i cant even smell anything under the hood.
Old Feb 13, 2007 | 03:09 AM
ham's Avatar
ham
i was just in the drive thru with the window down and i could smell coolant a little bit... there has to be a leak somewhere damnit!
i need to get a pressure tester.
Old Feb 13, 2007 | 09:35 AM
Jonknee's Avatar
sneaky **** haha
Old Feb 13, 2007 | 10:04 AM
spork motorsports's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">yea, im just saying it to eliminate a possible problem. and its easy. put your hand down there. done.</TD></TR></TABLE>
ya becuase that was a service bullietien huh? haha im serious i was cracking up when i read that email from honda
732xghost
Dec 22, 2006 07:22 AM
hondaracin24
May 11, 2006 08:56 PM
jvonb
Dec 2, 2005 03:15 PM
deechiguy
Mar 4, 2005 08:53 AM
Blue teg
Dec 17, 2001 07:21 PM
