Custom ITBs question
Will I be able to use these motorcycle itbs to make a itb setup for my d16z6? I know I would have to cut my stock intake manifold and weld it to the itb's, but how would I go about using my fuel rail and injectors? I got these real cheap, but I wasn't able to do research on them, but I did not want to pass them up. Here are some pics....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">for the price it would cost you to make that custom setup it would be cheaper to buy the omnipower ITB's
are those even out yet?
</TD></TR></TABLE>are those even out yet?
do not weld the throttles to the intake runners. You will warp the throttles that way. Been there done that, slapped myself.
those throttles will be hard to use unless they already line up with the stock runners. You cant separate those which makes it hard to evenly space the runners to achieve a straight shot to the intake valve.
They look like honda throttles. What size are they?
Guest
Posts: n/a
I'm sorry im new to this ITB thing. What kinda power can u expect from that? also, how much wear considering u can just mount a filter on that somehow... or how do u filter out dust particles and stuff, like following traffic through a construction area... and after doing that going turbo is out of the question huh..... and do u then have like, multiple air density sensors? and wow it just looks wierd and pointless, sum1 give me a quick schooling...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmeyer99 »</TD></TR><TR><TD CLASS="quote">This is coming soon instead.
http://www.aspenesco.com
I would have to see a video of that to comprehend how it works.. I don't understand the position (and point) of the throttle body because it's not channeling air anywhere.
The problem is that they're still made by Omni
</TD></TR></TABLE>The problem is that they're still made by Omni
the red things are stock injectors for the bike...we jb welded those holes shut on mine and then when we adapted the throttle bodies to the stock flange we left the stock injector holes on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earthworm Jim »</TD></TR><TR><TD CLASS="quote">The problem is that they're still made by Omni
Hmm... when was the last time i heard bad about Omni products. It's been a while. I think Omni finally step up in there quality.
</TD></TR></TABLE>Hmm... when was the last time i heard bad about Omni products. It's been a while. I think Omni finally step up in there quality.
