e non a/c radiator ok?
I have a stock 91 std hatch, not factory equipped with a/c. I just put in a/c from another ef. Is it safe to use the stock 1" thick non a/c radiator, or will the car overheat?
thanks in advance guys!
Modified by budomove at 7:08 AM 2/11/2007
Modified by budomove at 6:30 AM 2/12/2007
So you are asking if you can cut your radiator in half???? Unless you are skilled with a welder, I would strongly advise against that.
You need to do a little bit more research, bro. Lots of guys are running EG and DelSol half-sized dual-core radiators with custom mountings and whatnot.
A better option is a Neon radiator (yes, Dodge Neon). It is shorter and even uses one of the lower mounting points.
Provided that you don't have something taking up a bunch of room in the place the stock AC pieces would be (eg. - turbo/manifold, etc), you should be able to bolt it up in that location without issue using the stock radiator.
let me simplify and clarify:
i have a non ac std hatch (all stock)
i just put in ac (from another ef)
i would like to know if the stock 1" thick! non ac radiator would provide sufficient cooling with both fans attached.
thanks!
thanks!
greenzchatch
Jul 25, 2010 12:40 PM
GasDreamz
11
Apr 11, 2009 01:45 PM
808State
Jan 24, 2007 08:10 PM
