4th Gen Lude Question
Old Feb 10, 2007 | 02:08 PM
miguel_aka_timon's Avatar
Default 4th Gen Lude Question
Well im considering buyin some 17" motegi rims, but i am unsure in what my offset is.
Can anyone tell me what is is?
Old Feb 10, 2007 | 02:34 PM
Hawkze_2.3's Avatar
Default Re: 4th Gen Lude Question (miguel_aka_timon)
The offset is in the wheel.
Old Feb 10, 2007 | 02:59 PM
kulrevon's Avatar
depends on how wide you get the rim. I believe its 40 or 43 or so
Old Feb 11, 2007 | 10:14 AM
Default Re: 4th Gen Lude Question (kulrevon)
Well its 40 on the motegi rims im debatin about.
Old Feb 11, 2007 | 10:25 AM
M2B4's Avatar
copied from: http://www.ottawaprelude.ca/ya...=2886
OFFSET:
6.5" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.
Old Feb 11, 2007 | 05:42 PM
Default Re: 4th Gen Lude Question (M2B4)
thanks for the help. im guessing these wont fit ma lude b/c im lowered.
Old Feb 11, 2007 | 09:39 PM
M2B4's Avatar
it all depends on the offset.
bigmike321321
Oct 5, 2008 05:47 PM
j.dizzle
Apr 10, 2007 01:33 PM
mlow634
Dec 16, 2006 02:31 PM
K-Spec
Sep 26, 2006 07:54 PM
prahjekt
Apr 9, 2006 07:07 AM
