Car rev fluctuates when idling, HELP!!!
My car will fluctuate rev while idleing, it revs up and down, up and down, WTF is this?? It only does it when I an sitting at idle.??? Help!!
Unless it is the fan switching on and off, It is most likely the Ignitor coil in your distributor. If you have the manual you can check it with a multimeter, or if you have a friend with an Integra you could switch the coils and see if it fixes it.
I think new ones are around $130, but I'm not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 »</TD></TR><TR><TD CLASS="quote">i was reading some articles on TI.net and came across the IAC possibly being dirty and can cause fluctuations in idle.</TD></TR></TABLE>
yeah. my car used to do the same thing ....but it was the fast idle thermo valve, but just found out my iac valve is bad....
i would check out the
iac
and the
fast idle thermo valve..
iac
and the
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS’R’ »</TD></TR><TR><TD CLASS="quote">how much in rpm is the fluctuation? </TD></TR></TABLE>
It fluxuates from below 1000 (normal idle), the whole way to 2k.
Don't want to thread jack, but my car is doing the exact same thing and I just cleaned my IACV with no improvement. Any thing else it could possibly be if he does that and it is unsuccessful?
lshatch92
21
Oct 28, 2005 06:38 PM
4runner, acura, bad, car, fluctuates, fluctuation, fluxuating, idle, idleing, idling, integra, rev, revs
