Does the d16 manifold fit the d14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">there was a d14 in a 99 sedan?</TD></TR></TABLE> Correct<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">he messed up on the code.</TD></TR></TABLE> Wrong, overseas this was an option. User RACEPAK has one over in Israel, and there's another user from Jordan who has one as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goosse
»</TD></TR><TR><TD CLASS="quote">first, congrats, you have one off the slowest 6th gens availeble. I got the same car :dance:
What engine is in your hatch? A D14A3 or D14A4. Depending on the country you are in Honda gave different hp at the 1.4i. The D14A3 has 75hp stock, the D14A4 has 90hp. If you have the A3, there is no reason to pannick, when you replace the intake valve with the valve of a D14A4, you will have the 90hp.
Specs of the engine (metric system)
D14A3
SOHC
stroke: 79mm
1.396l
compression: 9.1:1
max power: 75hp at 6000rpm
max torque: 110Nm at 3000rpm
the D14A4 is different only with max power and compression
max power 90hp at 6300rpm
max torque: 124Nm at 4500rpm
If you are trying to find performance parts for these cars, you'r in trouble. As for as intake, headers and exhaust other D series non-vtec parts will fit, but for internal engine parts like cams and stuff, there is nothing out there. These engines were only put into the civics in europe, so no japanese or american companies made products for this car.
If you have more questions, please ask</TD></TR></TABLE>
D14A3
SOHC
stroke: 79mm
1.396l
compression: 9.1:1
