Front Signal Lights
Refer to owner manual. They'll tell you.
Quick summary
-inside the fender there is a screw or clip. Unscrew or unclip that part, pull it back, change your bulb.
Check owner manual.
Quick summary
Check owner manual.
LMAO the owners manual would probably tell them to get a bank loan and go to the stealership service dept and pay a few hundred clams for a bulb change.
There should be a hole either from the inner side or underneath, that will let a long phillips screw driver remove the screw, then the outer side of the lense will be clipped into a slot.
Black R
Jun 20, 2005 03:17 PM
