Spark plug looks white/ashy
i pulled off my valve cover today so i cang et familair with doing a valve adjustment on my own and decided to pull one of the plugs to look and it looks like a white ashy color on the tip of it...according to c-speedracing it means im running lean...what could be possible causes? how bad is this?
edit: did a search and came out to it may jsut have been that i was idle a little bit before shutting down...im not throwing codes so i think im fine.
Modified by silentdeath12886 at 12:28 PM 2/10/2007
Don't all cars idle before shutting them off?
Without knowing anything about your car, no one could begin to diagnose a cause.
But if you seem to believe it is ok, then so be it.
92integraVTECgsr
Oct 24, 2005 04:59 PM
NZcrx88
Aug 2, 2002 01:46 AM
