looking for: how to install JDM cluster w/ electic speedo into 91 civic. ***searched
can someone give me a link or something to show me a pinout or some sort of schematic to wire this up?
i have an electric sender from a hydro tranny. i have the cluster in the car and pinned up so everything else works fine. I would just like an easier route than figuring this stuff out myself.
tia
**edit:
is the circuit similar to an EH stock electric speedo sender setup? if so... i can just mock it.
tia
**edit:
ok search and found many links let me know if this helps
http://www.geocities.com/Motor....html
http://b16a.honda-perf.org/cluster.html
http://www.angelfire.com/ca/DrOhm/SiRcluster.html
http://jdmfan.com/technical/cosmetic/sir_cluster/
http://students.washington.edu....html
not all will work. not all will give every bit of info you need. but its a good starting point to get you going in the right direcetion
yes, i have the plugs. and everything is working, except speedo, but i need to figure out where to splice my electro speed snsr in. in the schematic says there is a pin for speedo signal and is wired in but need the snsr hooked up so it gets a signal. there is three wires on the snsr, one is ground, the other signal, and the other 5 volt reference. the 5 volt ref comes from the ecu but where does the signal wire splice in. the ecu or the cluster.
some pin outs for an obd0 ecu could help also
thanks for the info. but not enough. but a plus is now i know the pin outs for the doors and hatch on the d-plug. couldnt find the info for the d-plug either. but now i have them thank you
