who carries/makes the cf panels for a S2K cluster swap?
Like the title says, who produces the CF panels that cover the open areas of the gauge cluster opening for when you do a s2k swap in an EK?
i wouldn't be checking here at h-t
first time i saw a s2k cluster swap was in k20a.org
they were using them cause - not only are they pimp - but they used the vss signal of the new k20s that come on the newer rsx, and si..
search k20a.org for the s2k cluster, you will get alot of info on it..
esp bout the devices u need to correct the speedo, and make your temperature gauges work
Judging by the appearance of the cut, it looks to be something the owner fabricated.
You can find blank C/F plates here: http://www.macqc.com/raceplates
zaxfire69
12
Apr 28, 2012 04:53 PM
axtran
Jun 6, 2006 02:23 PM
