Crx swap question
Old Feb 10, 2007 | 09:04 AM
projectlude92's Avatar
Default Crx swap question
Does a d15b7 out of a 92-95 civic bolt right up to a 91 crx that currently has d15b2
MagnaniEG6's Avatar
Default Re: Crx swap question (projectlude92)
it bolt up but the tranny wont
Old Feb 10, 2007 | 09:08 AM
Default Re: Crx swap question (MagnaniEG6)
the car currently is an auto, so if id have to switch to a 92-95 trans also?
Old Feb 10, 2007 | 09:16 AM
MagnaniEG6's Avatar
no you should use your auto fromy your d15b2. SOHC hydro tranny dosent work with SOHC cable tranny. Correct me if IM wrong. You have to convert your car to mutil point also and to OB1 and run the B7 ecu. If thats to much work you could use the intake from your d15b2 and distrubtor. Not 100% sure on that though
Old Feb 10, 2007 | 09:18 AM
ok thanks man, i think i might just do a bseries swap, maybe h i dont know yet. i want to switch the car to a manual, but if im gonna spend lots of $$ i might as well make it worth my while.
Old Feb 10, 2007 | 09:20 AM
MagnaniEG6's Avatar
Ya, I notice your from IL, Rockton wheres that. You might just want to sell your car and buy a car with a swap already in it.
Old Feb 10, 2007 | 09:28 AM
crxd15z6_minime's Avatar
i need help my car had a blowen head gasket i changed that now it wont start i dont under stand why. i have a mini me swap
Old Feb 10, 2007 | 09:33 AM
MagnaniEG6's Avatar
Default Re: Crx swap question (crxd15z6_minime)
check all your wiring? seems dum battery hook up write. PS you hijack his thread
Old Feb 10, 2007 | 09:37 AM
ILcrxsi1's Avatar
I tell doctors what to do
If you just need a motor to get it running I wouldn't be against putting in one of those, but if you are actually trying to go faster don't waste your time.
Old Feb 10, 2007 | 09:42 AM
my wiring is good and the car was running fine but now it dont even want to fire i checked and it is getting fuel but it wont fire. i changed the dizzy and still no fire
Old Feb 10, 2007 | 09:43 AM
should i chang the computer
Old Feb 10, 2007 | 09:59 AM
MagnaniEG6's Avatar
aww....check for power from your harness to the ecu and other connections. Fuel pump come one you turn the key?
Old Feb 10, 2007 | 10:07 AM
fuel pump comes on i am not getting spark but i changed out the dizzy and i changed the computer . i put new ngk plugs in it i checked the harness and every thing i am clueless
Old Feb 10, 2007 | 10:11 AM
my bad for stilling his fourm or what not
Old Feb 10, 2007 | 10:18 AM
MagnaniEG6's Avatar
just post in the ef section with your prob you get more respones
Old Feb 10, 2007 | 10:47 AM
rockton is down near rockford, yeah i like the car though it is almost rust free just started to bubble near the wheelwell
Old Feb 10, 2007 | 10:51 AM
MagnaniEG6's Avatar
Is it a hatch
Old Feb 10, 2007 | 11:13 AM
josh807's Avatar
chronic bubbles *shakes head*
Old Feb 10, 2007 | 12:07 PM
Yeah it is a CRX
roadrunn
May 17, 2008 01:36 AM
scuzz
Nov 4, 2007 02:09 PM
Hatchback_bandit
Jun 24, 2005 02:33 AM
slwazgsr
Aug 4, 2003 03:17 PM
lahight
Sep 22, 2002 10:50 AM
