Exedy clutch actin a fool
Old Feb 9, 2007 | 09:57 PM
justseeingifitistaken's Avatar
Default Exedy clutch actin a fool
ok so i replaced my clutch last october (along with the motor and transmission 2 days before i drove it from louisiana to california to ship it to hawaii) and ever since i did it has had this problem where starting off in 1st it 'stumbles' a bit, but if i come off at like 2500 rpms it does totally fine. also the 1st to second shift feels rough...no grinds, just rough. I dont know what the deal is but it makes me question if i know how to drive a standard anymore...j/k but seriously it is difficult to take off. anyone? thanks
EDIT: 88 dx with sohc zc and tranny..exedy clutch....oem zc flywheel.
Old Feb 9, 2007 | 11:59 PM
dr_latino999's Avatar
Default Re: Exedy clutch actin a fool (hondaJDMimports)
Did you resurface the flywheel when the clutch was installed?
Did you break in the clutch per Exedy's recommended 600 miles?
Old Feb 10, 2007 | 03:57 AM
v8Buster's Avatar
lol mine shifts rouigh but it only seems that way cause i dont have the tranny mount on if ur facing the car left side.
Old Feb 10, 2007 | 09:04 AM
Default Re: (v8Buster)
flywheel was from an ef7 that i pulled the engine from that had only 21000 km (I worked with an import company and pulled it from the car myslef). That thing was *minty compared to my old one. as for the 600 miles break in period.....i drove 1900 miles in 3 days exactly 2 days after i installed it so.....i guess i broke it in. i
about the mounts i replaced them with Honda OEM when i put in the new motor except for the front mount which was autozone (ive had a thread already about how crappy their mounts are already). Honda said they didnt carry that one any more. i was actually looking for a solid front mount and still am.
When i say the shift from 1st to 2nd is rough, it actually sometimes feels like the car kinda turns off and comes ona gain (i say this cause my radio turns off and my rpms say they are at 0 for a second between shifts).
Old Feb 10, 2007 | 09:07 AM
Default Re: (hondaJDMimports)
Solid Front Mount - JimFab made em, doesn't anymore.
Car turns off, sounds like a definite electrical problem, only way the distributor would stop sending a signal to the tach.
Old Feb 10, 2007 | 09:13 AM
Default Re: (dr_latino999)
yeah i hear you on the electrical, but it is more like when you dont give enough gas to get started and you stall out kinda feeling? but between gears? or if you are push starting it and it kinda stumbles at first? but this is only when i am kinda getting on it, to say pull onto the freeway from those stupid ramps that make you stop kinda thing. i though for a while it was my clutch alignment/adjustment so i have adjust the cable a few times back and froth and it does change the engagement of teh pedal but still this wierdness.
this sounds dumb but i swear it is happening. i was talkgin to my dad about it (mecahnic for 20 years or so off an on) and he thinks that i am just shifting wrong. he thinks i am being goofy about it
Old Feb 10, 2007 | 02:58 PM
is it possible that it is a transmission problem? it is from the sohc zc and it is an L3 tranny....maybe something stupid like axles or something? kinda stumped.
Old Feb 10, 2007 | 03:01 PM
Out of curiosity, any CELs present in the ECU?
Old Feb 10, 2007 | 03:03 PM
none whatsoever....every once in a while i get the tps sensor code but i already know it is tempermental...btw dpfi
prelude182
Mar 24, 2010 02:29 PM
91_civic_si_guy
May 2, 2005 06:05 PM
crx69
Apr 10, 2005 05:33 PM
punkkazzjoe
Sep 25, 2004 09:49 AM
Ronin Panda
15
May 11, 2003 05:05 PM
