most common swap mistakes or problems?!?
Old Feb 9, 2007 | 04:34 PM
I CRX I's Avatar
Default most common swap mistakes or problems?!?
first off let me say, im in the middle of a b18c1 swap into an auto crx and im just hesitating on pulling the old motor due to this being my first swap. im already past the point of no return being that ive already pulled the wiring harness and had it converted, purchased the b18c1 motor and mounts, and converted the car from auto to manual, but before i go any further i just wanted to ask if you guys can give me a list of common mistakes or problems that might accur while doing this swap. Im freakin dying to drive the car so i want to get through this as quick as possible but yet i cant get over the fear that im gonna Fu#$ sumthing up. any suggestions are apreciated.
Old Feb 9, 2007 | 04:46 PM
Zaakro's Avatar
Default Re: most common swap mistakes or problems?!? (I CRX I)
Worst case scenario. Starting the car and it blowing up.
Old Feb 9, 2007 | 04:48 PM
KickStart2323's Avatar
mostly its a wiring problem ..that people forget to hook up or they did a shitty job on the harness...just make sure you take your TIME..aslong you double check every thing you should be alright..
Old Feb 9, 2007 | 04:53 PM
I CRX I's Avatar
Default Re: most common swap mistakes or problems?!? (Zaakro)
oh how i hate you.........j/k yea thats what im trying to avoid. i mean ive already got alllot invested in this($3500 swap, $500 mounts, $300 harness- which i must say is the SHIZNIT!- thanks rywire). so i just wanna make sure i dont screw this up.
Old Feb 9, 2007 | 05:00 PM
ekb16's Avatar
you should of left the wire harness on both the motors and after you pull out the stock motor, set it side by side the b18c and do the wireing...it will be much easier that way...if you want to make it nice and stock, rip off all the black covering on your stock harness that you are going to be using and plug it all up to the b18c and add the wires for knock sensor, vtec, IAB and extend some wires that needs to be extended...double check your wireing and after everything is connected, take the black covering and cover up all the wires as good as possible and tape it all back up and then you should be good to drop it in
Old Feb 9, 2007 | 05:06 PM
I CRX I's Avatar
yea i figured wiring would be a bitch so thats why i sent mine out and let tthe boys at rywire hook me up, but what can i avoid dooing or what can i quadripple check to make sure my motor doesnt blow on me? i guess that my biggest concern
Old Feb 9, 2007 | 05:21 PM
ekb16's Avatar
well after its in the car, b4 you start it make sure everything is hooked up again, make sure u have oil in the engine, coolant in the rad. fuel line hooked up to the fuel first, spark plugs plugged up in the correct fireing order, prime the engine until the oil light turns off..then start the car and check it over for leak n stuff
Old Feb 11, 2007 | 05:25 PM
I CRX I's Avatar
any more pointers, cautions?
Old Feb 11, 2007 | 06:16 PM
s10cky's Avatar
Heres my advice man.
I was nervous too upon startup, i was like what if...
But you just have too trust that its gonna be all good as long as your not ghetto, though ghetto people do not know when they are...lol
Just make sure it has all fluids, coolant, gear oil and motor oil, make sure you run the right gear oil and lubricants.
If you have a rywire.com conversion harness you deff. have a head start, my rywire harness truelly was plug and play, no issues.
If its a stock motor, just run the stock ecu, you should have any problems.
If the motor cranks up and blows up or spins a bearing it most likely had problems before you purchased it.
I think by the looks of your current state that you'll be fine, just take your time. Do not drive the car untill it is truelly ready too drive, even if it is tempting.
Old Feb 11, 2007 | 06:41 PM
oodie's Avatar
Default Re: (s10cky)
Get new waterpump timing belt all the things that should be replaced clutch etc because it is easier to do while out the car and while the motor is out clean up the bay with simple green and make sure the wiring is good you have rywire so you fine
...k20...
K Series
31
Apr 17, 2012 06:32 PM
Doostur
Jun 29, 2005 07:01 AM
ASSASSIN
Aug 27, 2004 04:02 PM
mztykal
May 27, 2003 07:19 PM
