toda power b16 problem
Old Feb 9, 2007 | 03:24 PM
zenon8890's Avatar
Default toda power b16 problem
i have a 1997 4door civic with b16a including these:
1- toda stg2 cams+cam gears
2- toda high compression pistons
3- toda head gasket
4- toda stage 2 clutch and disk and flywheel
5- lsd tranny
6-toda power chipped ecu
7-b&m fpr
8-walbro 255hp fuel pump
9-sparco air intake system
10-DC headers.
i'm running the stock b16 injectors.
the problem:
the car is freaking fast on first two gears, but when i hit the third gear i loose all power, but on 4th and 5th gears its fast as hell.
whats the problem with my 3rd?! is it injectors?! i did my timing issues but i still have the same problem.
can u help?!
Old Feb 9, 2007 | 03:45 PM
cambopheonix56's Avatar
Default Re: toda power b16 problem (zenon8890)
I think its in your head? What is your injector duty cycle at?
Old Feb 9, 2007 | 03:47 PM
KLiK's Avatar
or the shifting?!
where do the rpms drop from 2nd to 3rd?!
Old Feb 9, 2007 | 04:06 PM
Jdmb16sir2's Avatar
Default Re: toda power b16 problem (KLiK)
you should really get a b16 tranny
Old Feb 9, 2007 | 04:08 PM
Lscivic1999's Avatar
Default Re: toda power b16 problem (Jdmb16sir2)
i dont think the injectors have anything to do with you losing power on the 3rd gear...if it was that injector you'll losing power in all gears
Old Feb 9, 2007 | 04:48 PM
doood's Avatar
been there done that
sounds like you need a tune
wtf is a toda power chipped ecu? ebay chip? by stage 2 cams i assume you mean toda b's?
Old Feb 9, 2007 | 07:15 PM
zenon8890's Avatar
the chip i got from toda power when i ordered everything, i have a b16 tranny (ctr), when i shift from 2nd to 3rd my rpms drops from 9600 to 7600rpm thats all u need to know guys
Old Feb 10, 2007 | 07:45 AM
KLiK's Avatar
Default Re: (zenon8890)
and where does it drop from 1st to 2nd?!
and where does it drop from 3rd to 4th?!
and did you get the dyno results?! where is the HP peak?!
Old Feb 10, 2007 | 10:26 AM
zenon8890's Avatar
i dont have any dyno, (stupid middleeast) from 1st to 2nd it drops to 8300 and so does from 3rd to 4th
Old Feb 10, 2007 | 10:29 AM
9200RPM's Avatar
sounds like a tuning issue...i would upgrade injectors as well...im sure toda power could help you with that issue since you have used all of there parts
Old Feb 10, 2007 | 10:33 AM
95DxSi-R2
Guest
Posts: n/a
diff. 3rd gear? did u run the engine, tranny combo before all the upgrades?
Old Feb 10, 2007 | 01:49 PM
zenon8890's Avatar
Default Re: toda power b16 problem (95DxSi-R2)
yes it was ok before all toda goodies, the guy from toda shop told me its cuz of my dizzy wiring, cuz its not original and it've been cut before
Old Feb 11, 2007 | 02:07 AM
KLiK's Avatar
I still thnk it'sd the shifting...did anyone else try to run the car?!
Old Feb 11, 2007 | 11:08 AM
zenon8890's Avatar
yes and they all had same problem
Spoonson
20
Dec 8, 2009 07:58 AM
dohcbag
Aug 19, 2004 02:27 PM
ithrowpoop
Jun 17, 2002 10:26 PM
JDMchris
May 28, 2002 09:55 PM
valentinecr
Aug 21, 2001 03:14 PM
