GS-R exhaust fitment
Old Feb 9, 2007 | 02:53 PM
GSR0770's Avatar
Default GS-R exhaust fitment
What is the difference between exhausts on 94-98 GSR vs. a 99-01? Is it hanger locations / bends? How much modification would it take to put a newer model GSR exhaust on an older Integra? Thanks in advance
Old Feb 9, 2007 | 03:00 PM
akandok's Avatar
Default Re: GS-R exhaust fitment (GSR0770)
i had a civic si exhuast on mine... they all should be the same. if they are oem there might be a slight difference but not big.. if you get aftermarket should be same
Old Feb 9, 2007 | 03:07 PM
GSR0770's Avatar
Default Re: GS-R exhaust fitment (akandok)
I'd be replacing my stock 94 exhaust with a newer aftermarket if that helps....
Old Feb 9, 2007 | 03:09 PM
doood's Avatar
been there done that
the 99+ gsr's had a longer a-pipe and to compensate a shorther b-pipe
Old Feb 9, 2007 | 03:15 PM
GSR0770's Avatar
Default Re: GS-R exhaust fitment (doood)
Thanks, thats exactly what I was looking for!
Does that mean if I get a header/dp for a 99+ GSR the fitment will work?
Old Feb 9, 2007 | 08:07 PM
tomithy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR0770 &raquo;</TD></TR><TR><TD CLASS="quote">What is the difference between exhausts on 94-98 GSR vs. a 99-01? Is it hanger locations / bends? How much modification would it take to put a newer model GSR exhaust on an older Integra? Thanks in advance </TD></TR></TABLE>
94-99 and 00-01 are different not 94-98/99-01. If you get both the header and cat-back it should fit. You won't be able to mix and match them and have it fit without modification
Mikes2000civicsi
Nov 17, 2006 12:36 PM
TiredToyotaDriver
Jan 31, 2006 11:38 AM
SikGsrHatch
Aug 27, 2004 07:29 PM
99silverbullet
Jun 3, 2003 02:25 PM
