need help with turbo timer install, b16 head swap, and koni yellows/H&R springs, and Head Repair
Old Feb 9, 2007 | 02:05 PM
nexgen91's Avatar
Default need help with b16 head swap, and koni yellows/H&R springs, and Head Repair
Q: I am putting a SIRII head on my SIR I block, due to head damage and am wondering how I set the new head to TDC, or if this is required?
Q: I bought a set of Koni Yellows, waiting on them to get here, I have a set of H&R springs, but Im not sure what spec they are, I am pretty sure they have a rating of 250/60F and 250/40R which seams wierd, but I dunno. Is this ok to use?
Q: Lastly, my old head had a grove where the camshaft rest, i run my fingernail accross it and it kind of catches, but not to much, there is also a tap stuck in one of the Valve Cover bolt holes, can the grove be repaired or is this head toast?
Thanks
Modified by nexgen91 at 10:03 AM 2/10/2007
Old Feb 9, 2007 | 03:07 PM
91ed9's Avatar
Default Re: need help with turbo timer install, b16 head swap, and koni yellows/H&R springs, and Head Repair
Try FI?
daytonagp4
Aug 3, 2012 06:06 AM
96ej8MR
Jun 27, 2007 05:37 PM
nexgen91
Feb 10, 2007 04:42 PM
RagingAngel
Jan 21, 2003 10:16 AM
