dohc zc tranny and 88 crx tranny the same??
i have search and could not find if the 88 crx tranny and the jdm dohc zc tranny is different...can some help me out b4 i order a clutch..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">The DOHC ZC tranny should still follow the input shaft rules, someone correct me if I'm wrong.</TD></TR></TABLE>
Yes it does, it's still considered a d-series tranny.
i dont even know what kinda tranny i have....cause i got a zc dohc BUT i have searched and 88 tranny is different from 89-91....if my tranny is a zc tranny what clutch would i buy???or does that depend on the year too???
Well this is where it gets interesting.
88 Transmission + Stock Flywheel
Input Shaft Splines = 21
Clutch Size = 190mm
Clutch Application = All 1988 Civic / CRX
89 Transmission + Stock Flywheel
Input Shaft Splines = 20
Clutch Size = 200mm
Clutch Application = All 1989 Civic / CRX
90+ Transmission + Stock Flywheel
Clutch Size = 212MM
Clutch Application = All 1990-200 Civic / CRX / Del Sol
Now what do you do if you have the 1988 Transmission and want a larger clutch?
88 Transmission + 90+ Flywheel
Clutch Size = 212mm
Clutch Application = All 1986 - 1989 Accord
Clutch Size = 190mm
Clutch Size = 200mm
Clutch Size = 212MM
Clutch Size = 212mm
thats a good post...thanks man....i have ordered a 89 oem clutch from dakin...i hope it works....if not i have bought the wrong clutch...(i hope not)--if so i will order one for a 88 crx..
does the jdm zc tranny use 89 clutch??
ShiroX
Aug 20, 2003 05:53 AM
