need some wiwirng links quick!!!!!!
i need the shock tower plugs diagram for an ef, and an eg. I need to know what each wire is on the ef side from the shock tower into the engine.............and the shock tower to the motor for an eg.
So i pretty much need the color codes for each wire for an eg and ef engine harness.
Thanks in advance guys.....
They don't exsist.
I've searched high and low for them, downloaded every manual I could find.
All I can say is the color of the wires seems to stay the same, match them up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">They don't exsist</TD></TR></TABLE>
The firewall plug pinouts are in your manual?
Check again to make 100% sure because I don't believe you.
When I swapped a CRX, I needed to find the difference between the different years of HF wiring harnesses. I looked through Helms, Haynes, etc and they all had lots of wiring schematics but none of them had pinouts for the firewall plugs like this guy is asking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">I've yet to find them, the only ones I've ever seen on here is this one:
Yup, that's the only one I've ever found too. Kinda frustrating, it's only the one plug and it doesn't say what year it is for.
</TD></TR></TABLE>Yup, that's the only one I've ever found too. Kinda frustrating, it's only the one plug and it doesn't say what year it is for.
Yup, that's the only one I've ever found too. Kinda frustrating, it's only the one plug and it doesn't say what year it is for.</TD></TR></TABLE>
Yea, if only the community would quit bein lazy and start contributing....
there's enough people on this site, every year/model of CRX is owned. If people would take 10 minutes to go out to their garage, very useful info could be utilized by everyone.
oh well, thats why HT sucks ***** these days
maybe you guys should spring for a conversion harness and stop buying/doing hackjob *** harnesses
http://www.rywire.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodcivic510 »</TD></TR><TR><TD CLASS="quote">maybe you guys should spring for a conversion harness and stop buying/doing hackjob *** harnesses
http://www.rywire.com</TD></TR></TABLE>
With all due respect to RyWire, dont knock people for doing something themselves when its
A.Fairly easy
and B.Cheap
RyWire is expensive, I myself own 2 of their harnesses and 1 I've actually had problems with, and looking back, I wish I'd have just done it myself since its so simple.
I mean, if you can depin and solder, and have basic problem solving skills your set
But if your lazy, go for RyWire, but in the mean time dont waste a post just knockin someone for bein ambitious
A.Fairly easy
and B.Cheap
