lowering spring problem
Old Feb 9, 2007 | 07:01 AM
BlueRex1020's Avatar
Default lowering spring problem
alright so my friend throws on my kyb agx's and my k sport lowering springs. The front of my car is slammed n tucking n its on 13 inch stealies. The back is supper high to the point which i can see the springs. He did put the smaller stiffer springs in the front and the wider softer springs in the back but the ksport logo on the back ones is upside down. He said that was the way they fit. Did he do something wrong or did they send me da wrong springs?
Old Feb 9, 2007 | 07:40 AM
Str8 outta Cliff's Avatar
Default Re: lowering spring problem (BlueRex1020)
Sounds like he put the springs on backwards. Usually the rear springs are longer, but the fronts are stiffer. You should be able to read the writing with the springs installed.
Old Feb 9, 2007 | 08:26 AM
Default Re: lowering spring problem (Str8 outta Cliff)
by backwards u mean he put em on upside down? does anyone have pics of a rex or hatch with k sport lowering springs?.....he also said the rear springs looked to be too long so even if they are upside down, would it make a difference?
Old Feb 9, 2007 | 09:31 AM
danmdevries's Avatar
Not upside down, but rears on the front and fronts on the rear
I did the exact opposite. I had the spring perches reversed, and my front end was sky high and the rear was slammed.
Old Feb 9, 2007 | 03:18 PM
Default Re: lowering spring problem (danmdevries)
yea i asked someone dat i know dats been into hondas forever n dats what he told me....i gota get it changed tomorrow cus its tucking on 13 inch stealies n ill loose dat oil pan quick..
Old Feb 9, 2007 | 03:32 PM
oh n it turns out that the smaller stiffer springs were in the back n da softer wider springs in da back...
Old Feb 9, 2007 | 04:43 PM
Default Re: (BlueRex1020)
front*
Paluce
Suspension & Brakes
Dec 8, 2008 08:59 AM
power11
May 15, 2007 11:02 PM
Wazup
Suspension & Brakes
Feb 6, 2006 10:46 PM
Thanks knightsport!
Dec 1, 2005 04:46 PM
NINJASPY
Jan 16, 2004 10:46 AM
