Moroso RR oil pan on '99 GS-R?
I want the 5.5 quart Moroso road race oil pan (no. 20910), but it's listed for the 1994-98 Integra 1.8L VTEC and non-VTEC. I have a '99 GS-R engine. Will this pan fit with the factory pickup?
I'm having trouble finding info about a difference between the '98 and '99 bottom ends, but I'm guessing that the '98 might not have the block girdle that the '99 GS-R does.. if that makes a difference in the pans.
Does anyone know? Thanks.
The only difference I know of is the 99+ versions changed the cat and o2 sensor locations. Maybe there is interference with the stock exhaust? So far as I know all the GSR motors came with the girdle. Early motors had the oil squirters but that has no effect on the pan fit.
blocks are identical. all b18c blocks have the same pickup location and oil pan mounting. Do they list the same part # for vtec and non vtec? non vtec has a different pickup/pan design, so I am guessing they make seperate pickups, or both use vtec style. . .
