new to the crx, just bought one, got a few qusetions
I just bought an 88' si with a b16 swap. it needs the driver's side bearing tightened. I was just looking for how to tighten it. and also is there any right up on how to remove the front and rear bumper covers? my bumper cover brackets are bent. thanks, any help appreciated
thankyou very much, well appreciated
I was told my rear bumper cover brackets were bent, where can I find new ones?
but does anyone know how to tighten the driver's side wheel bearing?
I was told my rear bumper cover brackets were bent, where can I find new ones?but does anyone know how to tighten the driver's side wheel bearing?
yes it is a 32 mm i use an inger sol rand impact to take thoose of at work nothing like 1000 ft pounds of torque at my fingertips. good luck if you don't have air tools, but you want to tighten it so use a nice breaker bar and a pipe
ITs probably going to be a bad wheel bearing . they are a big sealed pressed in bearing . tightening that nut will tighten the axel into the bearing not tighten the bearing. you need to jack up the car wiggle the wheel back and forth and up and down and see where the play actually is. IF you dont have a press you wont be able to replace the bearing yourself.
oh ok thanks. I know of a few shops that will do it for a reasonable price
another thing, is there a way to align a bumper cover, or do I need new supports. and what cars can I use the supports from?
thanks
thanks
Wrath of VTEC
Mar 8, 2003 08:43 PM
OldSchoolHatch
12
Oct 31, 2002 04:58 PM
