95 honda accord
hi i'm doing a clutch and want to change the rear main seal and i already got it from honda but i;m not sure if its the correct one can i get confirmation
http://estore.honda.com/epc/asp/rjane007.asp#
numer 19
http://estore.honda.com/epc/im...A.png
once again REAR MAIN SEAL GUYS THANKS ALOT
numer 19
Honda P/N 91214-PH3-751 or different manufacturer 91214-PR4-A01
Size 80X100X10 Been the same flippin seal since 1984.
Easy way to remove the old seal; punch a small hole in the face area of the seal, then run in a small sheet metal screw 1/2 way, grab the screw and give it a jerk or use a pry bar on it.
Top Tech Tip of the Day
