TURBO KIT QUESTION
Old Feb 8, 2007 | 03:04 PM
Fl1pkidd's Avatar
Default TURBO KIT QUESTION
I have a question, If it says Direct Bolt-On that means that I dont have to removet he a/c right? I am unsure and Need some awnsers I'm just curious as to if anyone knows if these kits require the removal of your a/c.
I have a 1995 Integra with a B18c1 Type R in it. If that helps
http://www.raceinspired.com/p-....aspx
http://www.turbo-kits.com/integra_turbo_kits.html
Old Feb 8, 2007 | 03:20 PM
nate_2k5's Avatar
Default Re: TURBO KIT QUESTION (Fl1pkidd)
it says it was designed for use with or without a/c right in the ad
Old Feb 8, 2007 | 03:28 PM
Fl1pkidd's Avatar
http://www.importcarpartsplus.com/revhard.htm this is the kit im most likely going with
Old Feb 8, 2007 | 03:33 PM
nate_2k5's Avatar
Default Re: (Fl1pkidd)
the only ones it says that you have to are the early civics/CRX and the DA's so if you don't have those you will be fine
Old Feb 8, 2007 | 03:42 PM
ejmatzell's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fl1pkidd &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1995 Integra with a B18c1 Type R in it.</TD></TR></TABLE>
a what?
Old Feb 8, 2007 | 04:00 PM
nate_2k5's Avatar
Default Re: TURBO KIT QUESTION (ejmatzell)
yah that makes no sense
Old Feb 8, 2007 | 04:49 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fl1pkidd &raquo;</TD></TR><TR><TD CLASS="quote">http://www.raceinspired.com/p-....aspx
Wow .. worst WG placement evurr?
Old Feb 8, 2007 | 05:41 PM
BlangBlangTEG-93''s Avatar
a B18c1 type R?!!!!?!!! I dont think so, thats the GSR motor. The type r motor is the B18c5.
Old Feb 8, 2007 | 10:05 PM
B18 Piston's Avatar
Default Re: TURBO KIT QUESTION (BlangBlangTEG-93')
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlangBlangTEG-93’ &raquo;</TD></TR><TR><TD CLASS="quote">a B18c1 type R?!!!!?!!! I dont think so, thats the GSR motor. The type r motor is the B18c5.</TD></TR></TABLE>
holy **** ur so right!
Old Feb 8, 2007 | 10:33 PM
c1rcany12's Avatar
Default Re: TURBO KIT QUESTION (JDM front END)
Look into a Peakboost kit. They are around the same price.
Old Feb 9, 2007 | 06:06 AM
Hype-R Stalker
Default Re: TURBO KIT QUESTION (c1rcany12)
Wow, how many people have spazzed about about the b18c1 thing already,
he's probably not some blockcode *****, and really knows everything .. just a thought
And to add a little extra to the OP, searching would be good too,
with the kits you posted in the first post, you might need to know a little more about turbos.
Old Feb 9, 2007 | 12:10 PM
blacksheep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1rcany12 &raquo;</TD></TR><TR><TD CLASS="quote">Look into a Peakboost kit. They are around the same price. </TD></TR></TABLE>
he seems to be concerned about keeping his a/c.. if so the Drag or Rev Hard kits might be better for his needs. i mean some people gotta have their a/c.. i definitely understand that!
Old Feb 9, 2007 | 01:00 PM
LSTEG98's Avatar
i rether just piece a turbo kit thats wat im doing now
Old Feb 9, 2007 | 01:24 PM
Fl1pkidd's Avatar
Thanks for yalls answers, as far as the B18C1 thats just my code, it has more 5hp and 5 more torque than the regular B18C, and to what blacksheep said yes i am concerned with my A/C cause here in Florida it gets hot and I use to have a car with NO A/C so I gotta have it, and as far as the kit that im gettings its going to be the rev hard kit, 2650 shipped, and me and my friend are installing it ourselves, so hopefully everything works out and I'll be the fourth turbocharged teg in panama city
Old Feb 9, 2007 | 01:29 PM
LSTEG98's Avatar
good luck hope all goes well man
Old Feb 9, 2007 | 01:56 PM
1158's Avatar
If I were you I would ditch the FMU and get real engine management. I know some people have success with the FMU, but I wouldn't risk it...take a look in some of the archived FI threads about them.
Old Feb 9, 2007 | 03:13 PM
c1rcany12's Avatar
Default Re: (1158)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">
he seems to be concerned about keeping his a/c.. if so the Drag or Rev Hard kits might be better for his needs. i mean some people gotta have their a/c.. i definitely understand that! </TD></TR></TABLE>
That is true, if he were looking for more power though Peakboost would be a pretty good alternative. They also do have A/C manifolds
Good luck with whatever you decide on.
tpod
12
Oct 21, 2006 04:23 PM
big-cat
13
Mar 22, 2006 05:13 PM
rhd
Honda Motorcycles
23
Nov 25, 2005 01:54 PM
justinau
Aug 14, 2004 09:53 PM
quik sol
Feb 13, 2004 07:34 PM
