Which wheel spacer should I use?
Old Feb 8, 2007 | 12:31 PM
Spoon*EK9's Avatar
Default Which wheel spacer should I use?
I've got some 15x6.5 Spoon wheels. +42mm offset.
I'm going to be installing some Spoon calipers.
My question is, what size spacer should I use on STOCK Type R studs? The tire shop has two options: 1/4" = 6.35mm; 5/16" = 7.9mm All I'm going to need is 5mm to clear the caliper. However, I think I'd prefer the stance with the 7.9mm spacer. Is this going to cause a safety issue? Am I going to have enough stud length to go with the wider offset?
Thanks
Old Feb 8, 2007 | 02:16 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Which wheel spacer should I use? (Spoon*EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon*EK9 &raquo;</TD></TR><TR><TD CLASS="quote">My question is, what size spacer should I use on STOCK Type R studs? The tire shop has two options: 1/4" = 6.35mm; 5/16" = 7.9mm All I'm going to need is 5mm to clear the caliper. However, I think I'd prefer the stance with the 7.9mm spacer.</TD></TR></TABLE>
You REALLY think you could ever tell the difference in looks from one and a half extra millimeters?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon*EK9 &raquo;</TD></TR><TR><TD CLASS="quote">Is this going to cause a safety issue? Am I going to have enough stud length to go with the wider offset?</TD></TR></TABLE>
Make sure you have at least six full turns on the lug nuts (and seven is even better); if not, get longer studs.
Modified by nsxtasy at 5:36 PM 2/8/2007
Old Feb 8, 2007 | 02:29 PM
Spoon*EK9's Avatar
Default Re: Which wheel spacer should I use? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
Haha...Didn't really think about it. Brain fart! I was only thinking numbers, not the visual difference.
Old Feb 8, 2007 | 03:06 PM
dualweberVW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You REALLY think you could ever tell the difference in looks from one and a half extra millimeters?
definately
Old Mar 13, 2007 | 08:49 PM
kidkombo's Avatar
Default Re: Which wheel spacer should I use? (dualweberVW)
supposedly 5mm will make it so that youre lugs are only tightened on by a couple threads...honestly for safety's sake get extended studzors lol
ilovejdm
Honda Civic (2006 - 2015)
25
Feb 28, 2010 05:46 PM
GV1390
17
Aug 19, 2009 04:13 PM
rice4life
Honda S2000
May 21, 2007 05:34 PM
Yellow Dragon
Jun 19, 2006 01:11 PM
Flux
Dec 11, 2003 12:24 AM
