short shifter answers needed
Old Feb 8, 2007 | 11:47 AM
liftandcut's Avatar
Default short shifter answers needed
Ok, which dual or single-bend short shifters are a reduction in height from stock, and which of these are quality products? It's so hard to tell about height reduction from the ads online. Thanks!
Old Feb 8, 2007 | 11:56 AM
IHTFP's Avatar
Default Re: short shifter answers needed (liftandcut)
most of them are shorter in height..
look for stainless steel and steer clear of ebay cheapos and make sure to get new shifter bushings too...
ive got a skunk2 dual bend and new ES shifter bushings..its great
Old Feb 8, 2007 | 12:02 PM
SuzukaBlueAP2's Avatar
Default Re: short shifter answers needed (IHTFP)
TWM Performance was by far the best shifter I ever installed in my Integra.
Lowered **** height 3" and reduced throw distace my 55%.
Old Feb 8, 2007 | 12:21 PM
IntegraDOHCter's Avatar
Default Re: short shifter answers needed (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">TWM Performance was by far the best shifter I ever installed in my Integra.
Lowered **** height 3" and reduced throw distace my 55%.</TD></TR></TABLE>
+1. I personally don't have one in my teg (dc one...its great until I messed with a TWM) but my next shifter will be a fastline or TWM and definitely DEFINITELY buy some stabilizer bushings
Old Feb 8, 2007 | 12:25 PM
liftandcut's Avatar
Default Re: short shifter answers needed (IntegraDOHCter)
Thanks for the advice. So you have the TWM stage 2 shifter. I am having an Exedy stage 1 clutch and Exedy flywheel installed on my car. Is it just a matter of preference as far as which stage TWM shifter to buy, or is one of the shifters better mated to a stage 1 clutch and 9.5 lb flywheel upgrade?
Old Feb 8, 2007 | 12:26 PM
tweekerz's Avatar
Do not buy B&M. Mine rattles like crazy. Also, get ES bushings.
Old Feb 8, 2007 | 07:24 PM
liftandcut's Avatar
Default Re: short shifter answers needed (tweekerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tweekerz &raquo;</TD></TR><TR><TD CLASS="quote">Do not buy B&M. Mine rattles like crazy. Also, get ES bushings. </TD></TR></TABLE>
Ok, thanks. I think you gave me some other good advice a few months ago. Do you have any plans to go with another shifter any time soon?
Old Feb 8, 2007 | 08:56 PM
98GSRDC2's Avatar
skunk2 dual
Old Feb 8, 2007 | 10:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liftandcut &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice. So you have the TWM stage 2 shifter. I am having an Exedy stage 1 clutch and Exedy flywheel installed on my car. Is it just a matter of preference as far as which stage TWM shifter to buy, or is one of the shifters better mated to a stage 1 clutch and 9.5 lb flywheel upgrade?</TD></TR></TABLE>
better mated? None realy...its different alltogether...as far as actual mechanics go. I just want the shorte HEIGHT shifter...a common misnomer is that short shifters are just shorter "sticks". They actually change the axis angle therefore make the THROW shorter...
I drove a GSR with a skunk2 dual bend..I didnt really like it,but personal preference
Old Feb 9, 2007 | 02:16 PM
HYREV2NR's Avatar
I've got a cheap Check Point s/s dual bend w/ e/s bushings. Short in height & throw. The only reason I didn't get a TWM is it's more straight than the d/b which moves it forward a inch & a half or so. I don't like leaning forward to grab the stick. I already have the drivers seat all the way back.
Old Feb 9, 2007 | 02:43 PM
diagnostic's Avatar
i got the neuspeed short shift kit. comes with new bushings. personely, i think its the nicest feeling from a short shifter for honda's.
Old Feb 9, 2007 | 03:18 PM
c1rcany12's Avatar
Default Re: (diagnostic)
I've got the B&M short throw shifter on my integra. It squeaks a bit in between shifts, and has an annoying rattle crusing at higher RPM's. Other then that, it gets the job done.
Old Feb 10, 2007 | 10:52 AM
gsR_Ace20's Avatar
Default Re: (c1rcany12)
even though most ppl on here thinks it's ghey i have a DCsports shifter and love it, no problems so far
CeNCaL-DA9
Aug 12, 2007 12:15 AM
RHDintegXsi
Jul 23, 2006 04:19 AM
...civic...
Mar 15, 2006 02:37 PM
ieatrice
Aug 1, 2004 09:04 PM
95SiVTEC
Mar 29, 2004 11:36 PM
