Slight misfire
Old Feb 8, 2007 | 09:01 AM
Downz's Avatar
Default Slight misfire
hey guys today i noticed that my car has a minor misfire. its a 95 gsr. i was just wondering if u guys can give me some feedback on what some of the posibilities might be. thanks guys
Old Feb 9, 2007 | 01:21 PM
jess94-gsr's Avatar
Default Re: Slight misfire (downs1824)
have you checked a distributer cap? a minor crack not be visable to the eye caused mine. Check it for corrosion on the cap and rotor. I used a timing light and found that works very well. Also check anything to do with spark to put it bluntly, that's all I got for ya.
Old Feb 10, 2007 | 11:11 PM
98BabiGs-T's Avatar
Default Re: Slight misfire (jess94-gsr)
^ Plus spark plug wires and spark plugs.
Old Feb 11, 2007 | 12:02 AM
Haleiwa-Brando's Avatar
Default Re: Slight misfire (98BabiGs-T)
Not only the distributor cap, but check the condition of the rotor. If either or is worn (visible inspection) replace both at the same time. If you have a multimeter, check the spark plug wires for the proper resistance. Replace as necesarry. While you have the distributor cap off, pull the rotor and the protective plastic shield and check the primary and secondary ICM's. Check the condition of the spark plugs and check the gap.
Old Feb 11, 2007 | 06:52 PM
TIMMY4TOES's Avatar
this is the most general question, there is absolutely no way to know what the problem is. Thats like askin wheres the missin link
Noo_Ish_mee
Jun 27, 2016 02:44 PM
Nick Cronk
Apr 20, 2013 06:14 PM
whiterichard70
Feb 9, 2013 03:05 AM
halocore
Jan 8, 2010 04:20 PM
rdssk8rcs1
Jun 5, 2006 04:13 PM
